Bios is locked but I don't know how it locked need backdoor passwords
SOURCE: locked bios on dell inspiron 6400
Is there any clr cmos written on the board. The motherboards which do not have jumpers come with three point like solder on the board. You have to short first two manually with some wire.
If it is not there then you have to flush the bios with the bios flushing utility.
SOURCE: bios backdoor password needed.locked out of bios.
For those with Fujitsu Lifebook specially with PhoenixBIOS never remove your CMOS battery no matter what happened.Or else you cannot used your laptop forever....You will surprised 100% with these message
Warning
020F: PASSWORD LOCKED: Fixed Disk 0
F1 resume F2 Setup
So beware...
SOURCE: Corrupt & Locked Bios
When you flash the bios (normally from a floppy drive) it should overwrite anything that is there.
In this case you must boot from the floppy. Unfortunately, with a laptop you don't have that option.
I suggest you put the bios flashing utility that you probably downloaded with your bios update file on a flash drive. I think your laptop has the ability to boot from that.
Anyway, on startup, press F12 until you get the boot options and try that.
I take it that you know the support site URL, but just in case, it's support.dell.com
Testimonial: "Thanks much for the quick answer! I wasn't sure since Dell keeps laptop bios passwords on a separate chip from the bios itself. "
