SOURCE: Connecting this print server
information you need about your wireless network :
SSID or wireless network name
If the wireless network is secured, the security type (WEP, WPA) and the key (passphrase)
install the print server or access the setup user interface using the above information.
SOURCE: dpr-1260 onkly works when connected by ethernet cable
dpr-1260 searching for ap and connected keeps changing back and forth when I refresh.On dpr-1260 if status of wireless keeps changing from searching and connected, change wireless to WPA, instead of WPA2. even if you have WPA2 setup (as I did), if you choose WPA it will stay connected.
SOURCE: D-Link DPR-1260 print server setup problem
Try admin for logon & password.
Sometimes it is user ......
SOURCE: I have print server d-link
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
SOURCE: Cannot print, no connection Config D-Link Print
you need to change it to 192.168.0.0 - try that - it is the default address of the units.
Gary @ Fix Ya
