Hello, this is Ava with Think Crucial.
To change the wick filters of your humidifier:
1. Turn off the unit and unplug it from the wall outlet
2. Remove the tank for the housing.
3. Locate the 3 lock tabs in the base of the unit. Turn them clockwise until the base of the tab lines up with the indentions in the base and lift off the housing.
4. Locate and turn the lock tab clockwise on the base holding the wick fram. Remove the wick frame and set it aside.
5. Remove the old wick by pulling the bottom of the wick out of the frame first and discard.
6. Insert the new wick top first. Ensure wick is in between the tabs at the top of the wick frame then slide the bottom part of the wick into the fram, making sure not to crush the bottom corners of the wick.
7. Reassemble the unit and refill the water tank if necessary.
8. Turn the unit back on and resume operation.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?page=1&q=hunter&type=product
I hope this was helpful.
Ava B.
Think Crucial Customer Care
