It's possible to reset the DTXPRESS electronic drum kit to its factory default settings by performing a Factory Reset. Here's how you can do it:
Press and hold the [DRUM KIT] and [SAMPLE] buttons while turning on the power switch. The display will show "FACTORY RESET OK?" Press the [DRUM KIT] button to execute the factory reset. The display will show "INITIALIZING" while the reset is being performed. When the reset is complete, the display will show "COMPLETED". Note: Performing a factory reset will delete all user kits, samples, and other custom settings that you have made. Be sure to save any custom kits or settings that you want to keep before performing the reset.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Do a factory reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Normally the user-name & password for d-link routers are "admin". If it is changed by someone or forgotten, then there is a reset switch with a pin-hole at the rear of the router. It resets the router to factory settings. But this will erase the old settings required for your connection.
Tries tv and those cable or satellite boxes unplug,replug it back like about an hour later for those pay boxes to reboot and upgrade it softwares and for the tv to do a resetting itself back to factory setting,now go into the tv menu go to Audio setting tries resetting all back to the factory setting.By doing these steps.These steps,will help and have a great chances for ur tv to have it audio back for tv stations channels broadcasting reception.
We had a similar problem, but was with the audio side. You can attempt the system reset like this; Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this. Set MULTI-ZONE to OFF. 1 Switch the receiver into standby. 2 While holding down HOME MENU on the front panel, press ? STANDBY/ON. The display shows RESET ? NO ?. 3 Press ENTER on the front panel. 4 Select 'RESET' using ?/?, then press ENTER on the front panel. The display shows RESET? OK. 5 Press ENTER to confirm. OK appears in the display to indicate that the receiver has been reset to the factory default settings.
Hope this helps. I switched to Onkyo for my receiver.
Q:Does PictureMate have a factory reset button? A:Yes, you can reset the print settings to their original, default values. Press and hold down the Cancel button for 3 seconds. When the message to reset the printer to default settings appears, press OK to reset the print settings.
Note: This reset does not affect LCD contrast, Print Confirmation, or PictureMate Print Wizard settings.
