I have AppleTV hooked up, get picture...no sound. WHY?
SOURCE: How do you reboot the Denon AVR-2807 to factory settings
To reboot, turn receiver off by the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory. Enjoy this info is straight from Denon's Tech support. I had to do this on mine
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an
HDMI cable to the TV. This will give you a high def picture (set up the
PS3 to output the max resolution your TV displays). That will take care
of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3
menu, you have to change the audio settings to output the sound via the
optical cable.
Finally to get sound out of the receiver to the speakers, you have to
setup the receiver source input. For example if you setup the PS3 to
play thru "VCR" input, then you have to make sure the VCR input is
setup to use either optical 1 or optical 2 for sound (whichever one you
have the optical cable plugged in from the PS3).
SOURCE: no sound fom optical input
Do you have your TV hooked up, so you can see the AVR-4800 system menu on its screen (if not, see the manual). You need to go down to the digital input menu item where you associate each component with its input source, whether it is coax, optical 1, optical 2, ..., etc.
SOURCE: Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
