Televison & Video Logo
A
Anonymous Posted on Jan 06, 2014
Image interference (red 'speckles' & screen flickering) when watching TV through receiver.
I have a brand new Panasonic 55' LED 3D TV (Australia - THL55ET60A) that when hooked up to my Sony HT-SF1000 surround sound system (which includes Foxtel pay TV) starts to flicker occasionally within 5 - 10 mins. At the same time, noticeable 'red speckles' start appearing on the screen which appears to be some kind of electronic 'noise' or 'interference'. This is most noticeable when the screen colours are dark. Through a process of elimination (swapped Foxtel boxes & watching the TV normally ie. NOT through the receiver), I have identified the problem only occurs when using the Sony receiver. This is further confirmed by the fact that we had the TV replaced but the problem persists when using the receiver. I have had the receiver for quite some time and not experienced this problem before. The problem does not seem to occur when watching a DVD through a DVD player that is also hooked up to the receiver. The Sony trouble shooting guide indicates the front and centre speakers (5.1 surround sound) are magnetically shielded but the rear surround speakers are not. The rear speakers are 3.5m+ away from the TV and are not magnetically shielded but at that distance shouldn't be impacting on the TV. Whilst still watchable, this is a very annoying situation which on occasions results in the image disappearing completely. By switching the TV off & on again the image returns but the 'red speckles' and occasional flickering continues. Any help or advice you can give would be greatly appreciated. Kind regards Jeremy
rexine pigg
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jan 06, 2014
rexine pigg
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
9034
Points
5
How do i reset my jazzy? cant find my manual.
3 Related Answers
Anonymous
  • 50 Answers
  • Posted on Aug 11, 2008
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Anonymous
  • 98 Answers
  • Posted on Mar 03, 2009
SOURCE: Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Anonymous
  • 14553 Answers
  • Posted on Dec 06, 2009
SOURCE: I have a Panasonic PT-56Wx51E that started showing
This is really a very simple thing to diagnose---go into the customer menu and select convergence--if red or blue is skewed there and will not adjust in some direction--you have a convergence circuit problem.
These sets use two convergence IC chips--if convergence will not adjust you need to replace both chips along with any of the resistors around them that protect the set and are bad.
Parts are cheap for this ----less than 30 dollars for everything you will need.
Based on the Pt56wx51e model number this set uses two of the STK-392-110 chips--they are black and side by side on metal heat sinks with fins and will have the full STK number printed on them in white letters.
Most shops get 300 or more for this kind of repair. If you or someone you know can do it you can save a lot of money.
The repair really only involves two things: getting at the chips and parts and being able to unsolder and replace them.
I HAVE START TO FINISH STEP BY STEP INSTRUCTIONS FOR THIS REPAIR ON THIS MODEL. They will tell you everything you need to do the repair and how to do it--I have fixed hundreds of these sets with convergence problems.
If you think you can do it let me know and I will post the full instructions here for you.
Once the problem is fixed the set will not have the same trouble for 5-8 years--lifespan of the parts.
If this has helped you rate this solution as I do this here for free.
SD TECH
Testimonial: "The information was very informative and with it I will be able to fix the problem. Great response time, Thanks. Please post instructions for this. "
How to fix vertical lines on a panasonic viera 3D lcd 55" tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
2answers
How can i fix my samsung tv ? there is a black screen , no image , the sound is okay & the red led is blinking 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Screen flickers on and off
If all your other HDMI inputs are out, then I recommend replacing the MAIN PCB
try the following web site: https://www.encompassparts.com/model/ZEN55UB9500UA/_/_/LG/55UB9500UA/55_INCH_UHD_4K_SMART_3D_LED_TV_W_WEBOS
page 4 lists a part number for the MAIN PCB,
HOWEVER, PLEASE MAKE SURE YOU USE YOUR COMPLETE MODEL NUMBER TO ASSURE THE CORRECT PART.
Why is the 7 red blinks of *****
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Good day again my Samsung 55''un55es7500 led 3d tv has tin g oldish lines from top to bottom of left side of tv screen can you assist in fixing problem
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
BROKEN SCREEN
You now have a 55" parts unit !!! A replacement 55" panel will most llikely cost as much as a new set !
AKAI PT5598HD ghost image the red is offset
Replace STK392-040 IC's with name brand only. No generics.
I use Panasonic brand with no recalls.....Let me know if you
need more help.......................T.
Please rate this solution...........thanks.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
