The lens assembly for S3 is pretty complicate. I suggest you get a professional to handle it. It is usually the stuck shutter or failed motor that caused issues on S2 or S3.
There is a guy on eBay that fix both issues for a low price. Fix is for Canon S2, S3, S5 with stuck shutter. here is the link in case you need: http://www.ebay.com/itm/141414188140 and stuck lens: http://www.ebay.com/itm/141334025954
Avoid dropping or subjecting the camera to severe impacts. Do not ... 2006 CANONINC. ... When switching between shooting and ... The camera switches to Playbackmode, but the lens does not retract ..... Play/Print/Set up/ My Camera Menus.
Record Mode LCD Display: In Record mode, the PowerShot S3 IS's LCD reports ...Unlike its behavior in Record mode, the Display button will not let you view ... switchwith the red camera icon, this mode sets up the Canon PowerShot S3 IS ... exposure setting you've chosen if the camera can't get a good exposure with it.
galeria-zdjec.pl/ksiazki/instrukcje/Canon/canon_pss3_eng.pdf
Shoot movies in any mode by pressing the movie button ... with My Colors ... caused by the malfunction of non-genuine Canon accessories (e.g., ... warranty does not apply to repairs arising out of the malfunction of .... Switching between Metering Modes . .....Do not get the camera caught on other objects or subject it to.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Lens probably does not extend or retract because of debris or misaligned gear box. The
lens can many times be repaired without having to replace it. Try to
return to manufacturer. If you're out of warranty, there are
third party place that fix them such as camera lens repairs. There are also free camera repair guide websites that show you how to replace the lens, the part is usually available on ebay.
Most likely this is a shutter problem. If you are using flash and getting the half pictures, then make sure the flash is a canon compatible flash and the synch is set to 60th. If the problem is all the time including non-flash pictures, then the shutter will have to be repaired.
The lens mechanism had probably got some dust, sand or grit jamming it and stopping it from retracting. Sadly the lens will be difficult to repair yourself as it needs to be completly stripped from the camera. Find a good repair shop and get a quote locally.
I take it that you are using the same lens on the 500 all the time?? If that is the case then one of the interior lenses on the zoom lens are damaged. This, unfortunately, is not something you should tackle yourself. It is possible to open the lens up but you would probably not be able to buy the particular lens directly from the manufacturer and the risk of getting dust or moisture inside the zoom lens is quite high. Personally I'd take it along to a decent camera shop and ask them to give you a repair estimate so you can decide if it's worth fixing or as cheap to just replace it. Lens prices have come down a bit in the last few years so it's possible the repair and replacement would cost the same..
It's very possible that the problem is that the shutter is stuck, which is a known Canon issue on the powershot cameras, mainly on the S2 and S3 models, which it happens after some time (weeks or months) thata camera is not used.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires the skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S3".
Canon also uses the low battery Icon as a generic error code. Try taking the lens off the camera. If this fixes the problem the lens needs a repair (most likely the aperture unit). If not then the camera needs the repair (either the shutter or dc-dc converter circuit).
