I have a new tap but the swivel joint has become very stiff after a couple of months use. Can i fix this or do I have to replace it?
SOURCE: single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
SOURCE: stiff swivel
Hi
I tried lubricating the joint lightly with a little fine silcone oil at first, that just made it worse. By now the swivel action was almost non exsistent and the pit of my stomach had that churning, sinking feeling :0(
I'm an technician and quite handy, so I thought I have nothing to lose, I'll remove the outer casing and see whats what. I took the four screws out at the center of the swivel... and then quickly screwed them back in again. Not a good idea.
I thought the only I was giong to fix this problem was from the outside in. Ok, Im not advocating you try what I did but it definateley improved/freed up the swivel joint. I used a spray can of TF-90 Fast Drying Cleaning solvent. Im in the UK, I dont know if you can get this world wide. Its labled as as replacement for 111-Trich. Its really nothing like it, its more like electrical contact/cleaning/maintanace spray, it even has that same sweet smell. (a bit like 112- Trich) I sprayed the joint with copius amounts of the solvent taking care to aim just at the joint and not overspray. Spray, twist.compressed air. spray, twist, compressed air. Eventually the joint became much freer, not quite as smooth as new but at least the swivel now works.
If you have the same problem and follow what I did (I have not read anywhere about the same issue which I think is rather odd) be careful not to leave the solvent standing for any length of time as it tends to slightly melt the tops of the plastic buttons and could wipes the decals off if your not careful! Note, I would only attempt this method if you have access to a compressed airline to be able to blow the solvent clean off the camera. If you have had this pronblem in the past, I would be greatful if you would let me know how you got on. Cheers
SOURCE: Fixint the swivel hinge
The following website should help you out - if the problem is just a loose hinge. Maybe you've already seen this webpage, but here it is again anyway.
http://www.insidemylaptop.com/tighten-loose-display-hinges-toshiba-tecra-m4-satellite-r15-tablet-pc/
Your problem may be just a couplI used the directions to take off my screen and then found out my hinge was broken.
Good Luck
SOURCE: My HDR SR12 LCD backlight has become intermittent.
Can you share with me a email address that I could send the service manual to?
Thanks,
Ekse
SOURCE: Swivel would not move. As advised took handle
Either an oring is in wrong spot , something got in the spout and is blocking it, or the aerator is plugged
