Thank you your advice was successful. Also that this process should be done regularly.Thank you your advice was successful. Also that this process should be done regularly.
You can't post conmments that contain an email address.
at least once every four weeks but you will learn if you need to do it more often oo less with timeat least once every four weeks but you will learn if you need to do it more often oo less with time
check inside it may have a lot of lint build up in it, check the vent to outside and be sure there is no sharp bend in vent pipe to make it over heat. the straighter the better !
after 60 cycles it goes into the clean function, the clean light comes on..., remove the charcoal filter from the water tank, fill tank with 1/2 water and 1/2 vinegar if you want to clean it, just water if you want to get it out of clean mode..., press clean button/light for 3 seconds and clean button flashes and the cleaning process begins...It takes 60 minutes / 1 hr. to complete, light goes off when complete. reinsert filter in tank .
This is an easy process if you follow the instructions step-by-step. Some other advice for getting rid of washer odors in front loaders is available in this next link:
I personally own one of these washers and have never had an odor problem by following these tips. I've had the washer now for 8 years. It does work if you're diligent about maintaining it. I hope this information is helpful to you. Let em know if you have further questions.
Please take a look at the following link and see if you are following all the steps. Front Loaders are notorious for smelling this way , but there are things you can do to minimize the problem. I have owned a front loader for 8 years now and have never had a problem by following this advice.
