Question about Kenwood KM400 / KM410 Chef Classic Stand Mixer
Dough hook i have bought a new dough hook as the old was falling off because of its worn out condition but the new one does not click in! Can any one help
    New Friend:
  • 108 Answers
Hi, the new style tools do not fit old style mixers, yours probably had the small circlip on the shaft, the new ones dont have this, and it's this what held your tool in place
Posted on Jan 11, 2014
6ya staff
SOURCE:
What is spiral hook dough?
A Spiral Hook Dough Hook is one that is used for making bread dough. It mimics the action of stretching and kneading the dough by hand. This develops the gluten content which is the elastic part of the dough that traps the bubbles of carbon dioxide from the yeast.
Oct 14, 2017 | Food Mixers
Hobart h 600 mixer dough hook keeps coming off during operation. What would cause this
Take a look where the agitator pin engages with the dough hook.
Either the agitator pin (sticks out from the agitator shaft) is worn out or the groove in the dough hook where the pin should sit has elongated and worn. Either pin replacement is in order or new hook is required...possibly both.
Jul 04, 2014 | Food Mixers
What is the correct dough hook to get for my 'OLD' A200 Hobart?
Check with your local Hobart office.
www.hobartservice.com Click on "Locate an Office" and enter your Zip.
Jan 20, 2010 | Hobart A200 Stand Mixer
Having a hard time removing the dough hook on the h-600.
make sure the beater shaft is clean. is the dough hook new or old if its new you can deburr inside of dough hook to ease in install and removal of attch. please let me know so i can futher asist
Dec 03, 2009 | Hobart H600 Stand Mixer
Bread dough
IT NEEDS TO PROOF LONGER
Dec 10, 2008 | Hobart N50 Stand Mixer
Help with removal of Dough Hook on A200.
Force and a torch is your path.
First cut a block of wood that is of a length that is long enough to go from the column to the attachment portion of the planetary. (The block protects the gears from the force.)
Look at the rotation of the hook, you're going to twist it the opposite direction. Above the hook, loop a strand of a wet towel. While keeping the towel damp, not wet, torch the **** out of the hook. I recommend "mapp" gas. Heat it for about 90 seconds to to 2 minutes. The old dough stuck inside will burn off. You should get some black smoke. Use the block of wood, between the attachment portion of the planetary and the column, to resist the twist of the hook. If the wood is properly placed to absorb the load --- dampen towel, torch, block, TWIST. If you use a wrench -- be cautious. Good luck -- Mike
Jun 27, 2008 | Hobart A200 Stand Mixer
Dough hook
if you r using it for dough use the roller and scraper it works much better. But if u want to use the dough hook the holes in the middle is where the knob and stick in the arm go into to hold the hook inplace and it also goes in the hole on the side near the scraper hope this helps
May 30, 2008 | Magic Mill DLX 2000 Stand Mixer
Bosch aluminum dough hook has black coating
the problem is where the pin on the beater shaft locks into the hook may be wearing down or the hook itself.when you put the hook on see if you get alot of play in the hook (wiggle it and if it feels really loose its worn).its still safe to use but eventually (and this may be quite sometime) the pin may break off the beater shaft.you would then have to replace the pin and hook.
Jan 27, 2008 | Bosch 700 Watts MUM6622 Universal Series...
Hobart p660
There are 2 set screws.Make sure their both out,if for some reason there is only 1 set screw these are your options.Heat the shaft and remaining pin with a mapp torch (you can buy them at home depot,lowes for $40 bucks),heat it up really good then get a punch and try to knock out the pin,option 2---if you cant get the pin out then youll have to replace the shaft and if thats the case you should also clean out the planetary and replace the bearings and seals.If the hole in the shaft is oblongated or worn you should probably replace the shaft because the dough hook will rock the pin back and forth breaking the pin.Also look inside the hook and make sure thatI its not worn out where the pin sets.IF you see thee hook or shaft pinhole worn you will break the pin again if you are able to replace the pin.I work for hobart and service mixers regulary,if you need part numbers or advise let me know.
Nov 27, 2007 | Hobart P660 Stand Mixer
Kenwood KM400 / KM410 Chef Classic Stand Mixer Logo
85 people viewed this question
Top Kenwood Food Mixers Experts
Peter GW Fleming
Level 1 Expert
Treefrog15
Treefrog15
Yitz Diss
Level 1 Expert
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
