Samsung HT-X20 Home Cinema 600W Theater System Logo
R
RODRIGUE Posted on Jan 05, 2014
How to make my toshiba dvr50 dvd vcr region free
3 Related Answers
A
Anonymous
  • Posted on Feb 14, 2008
SOURCE: Region Free Samsung DVD-VR320
Try www.videohelp.com/dvdhacks
Anonymous
  • Posted on Sep 19, 2008
SOURCE: region free - Samsung DVD-VR375 DVD Recorder / VCR
I have managed to get a solution to this now. I have a region 4 as in Australia so depending on where you are you'll need to try the correct region. It worked for me first time. Point 4/ below my region code appeared in the top right corner for a couple of seconds not the top left! Once you've completed below turn the machine on again and stick in one of the dvds that would not work before.
Cheers Stewart
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767
or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
muntejaya
Muntejaya Ginting
  • 10422 Answers
  • Posted on Feb 27, 2011
SOURCE: code to change samsung dvd vr375 to region free
Hi there, please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay_er45r
1helpful
How do I unlock region codes on a Toshiba SE-R0220 DVD/VCR player? I've tried many codes for other toshiba DVD players but none of them work :(
The Toshiba SE-R0220 is the REMOTE model number not the DVD/VCR model number!
You need to find hacked firmware for the DVD/VCR model number you have that releases the region settings.
Write it to a CD RW or DVD RW disc and follow the instructions for updating the firmware.
There is a chance that the firmware will not update correctly and you'll be left with a DVD part of the system that doesn't work.
DVD region hack available?
If you suffer from region code troubles, you can download a region free DVD player software tool on your pc and then you can play discs of any regions you want. You can try Leawo Blu-ray Player which is a free Blu-ray player and a region free player.
2answers
CHANGE the REGION on my SONY DVD BDP-S185
From the users manual:
Region code (BD-ROM/DVD VIDEO only)
Your player has a region code printed on the
rear of the unit and will only play BD-ROMs/
DVD VIDEOs labeled with identical region
codes.
Nothing was said in the manual about changing the region code.
I need to unlock a Toshiba DVD player/VCR Combo SDV395 to view DVDs' purchased in Francs
You can change the Region Code of you DVD player but be aware that you have a limited number of changes, then the DVD player will be stuck to a certain region.
Search in the Options menu and change the region code to one printed on the french dvd case. To watch DVDs from your region again you have to change the region once more. Watch for changes left.
I cant play my moovies it will say region error how come?
Some DVD players have region coding only allowing discs to play specific to that country (or region) only . If you lucky you might find region hack online to re-program your player - just type <model number> region hack into Google. The alternative is internal modification which can be expensive - buying a region-free player would be cheaper.
3helpful
14helpful
5answers
UNLOCK CODE TOSHIBA DVD PLAYERS
unlock code TOSHIBA D-VR7KC
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
