SOURCE: wire diagram for splitter
On the 205064 hv splitter with the splitter mounted in the set,left to right, hv transformer,red tube,green tube,blue tube,plug on right side goes to screen asy,the black wires plug on the left side of splitter,which are grounds.
SOURCE: D52W19 RED LAMP
Good Day,
Yes, there may help for you yet.
Let me first comment on your posted 4-11-08 comment I like all of us on forum do don't make any $'s, I'm here to help you all.
Repair: Ensure that there is no holes in the HV wire, clean the surface around the anode at CRT, remove replace the cup and re-silicon cup and area.
Good Luck. God Bless.
SOURCE: I need the schematics of the control module
The model listed is an older set----usually if it HAS the splitter it is up front----but most there is not one as it is part of the high voltage transformer----look on the label on the rear where model number is for a Chassis number, that will tell me instantly if a splitter exists or not PTK-------
SOURCE: I need the schematics of control module hv splitter P52926S
This rear projection set does not per say have a control module and if has a high voltage splitter it is up front----follow the large red wire from the flyback to it.
