My microwave started beeping at me. Then it flashed a message to open and close the door and push start. It started cooking with a micro 22:22 on the display pad. After trying to clear thr pad and opening and closing the door numerous times, it now is displaying a 5E and every minute it beeps at me. What is wrong?
< - Let ME know your full model number from the tag and I can give you complete detailed instructions on how you or a friend can fix it.
"SE" means you have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
SOURCE: GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
SOURCE: door indicator prevents microwave from starting
This is usually an indication of a bad door interlock. Take resistance readings with the power turned off on the primary and secondary interlocks. You will need to remove the control panel to access them. There should be a wiring diagram somewhere inside the control panel to assist you in determining if the interlock is normally OPEN, or normally CLOSED. As you open and close the door the interlock should change states. Additionally, double all your connectors to make sure they are plugged in correctly. I had a similar problem once and it turned out to be a loose connection on one of the interlocks. I hope this helps you.
SOURCE: How to stop the beeper and reset the "code' light on panel?
You have a shorted 2 pad on the keypad.
Since
it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
SOURCE: Hi. I pressed the 'quickstart'
The
first thing I would suggest is a hard reset. Unplug the unit for a
minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Sounds like an intermittent door switch or a loose door switch mount. Very common.
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
