SOURCE: Samsung Synchmaster 940n - screen lasts 2secs then goes.off
#1 Make sure that you have only one input cable hooled up to the monitor. Using both DVI and VGA inputs from the same video card can cause this issue.
#2 Try both VGA and DVI inputs individually, make sure issue occurs on both.
#3 See if issue occurs connected to another system. Also boot this system to SAFE MODE see if monitor will then function at that resolution (It may be your system is set to a resolution the monitor will not display)
#4 If purchased recently, contact the seller. Most will honor a malfunctioning item. If not, contact EBay as there is normally a $200 MINIMUM buyer preotection plan,
SOURCE: synchmaster 2333 no red color
Rush to claim your warranty, the only thing you should do first is make sure that the input signal is OK: Hook up any laptop to any other monitor, then immediately (i.e. without changing what the computer is showing) hook it up to your monitor.
Another option is that you have a faulty cable. If it is part of the monitor, the warranty will cover it. If it can be detached from the monitor, borrow another cable to see whether that is the faulty piece.
