SOURCE: my tv lost its "sound". however, i popped in a
Hello
The sound detector section in your tV is faulty. It is composed of an IC, which filters out sound from the brodcasts or any RF signal we feed to it. The sound output secion has no trouble at all, that is why you can heare sound when you inserted and played a VHS tape. For tape playing this section is not needed, and it will be switched OFF when we play a tape. It will get energised only when any RF signal is fed trough its tuner. This IC should be repaced along with the sound detection crystal. It is really a skilled job, not a user repairable one. You have to open the TV, and have to pull out the main board for repair. Must have a sond knowledge in electronics and proper measuring equipments. OK.
SOURCE: sound and just a Static picture when playing a VCR tape on a Sharp 13vt-N100
More likely a damaged tape got inserted, if the video heads get blocked or even partly blocked every tape after will do this, heads can be cleaned manually (careful if not sure how to do it) or a cleaning tape MAY clear this up or not.
SOURCE: Sharp TV VCR combo sound and no picture
See my previous answer for this--most likely a blocked or bad video head in the unit (dirty or blocked is most common)
