Samsung LN-T4061F 40 in. LCD HDTV Logo
A
Anonymous Posted on Jan 05, 2014
Samsung tv closed caption grayed out - Samsung LN-T4061F 40 in. LCD HDTV
5 Related Answers
Anonymous
  • 137 Answers
  • Posted on Dec 09, 2007
SOURCE: closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Anonymous
  • 205 Answers
SOURCE: turn on closed caption on samsung LA32S81B tv
If you don't have the manual, go to this website:
http://www.samsung.com/in/support/productsupport/download/FileView.aspx?cttfileid=1383390&type=TV&typecode=&subtype=LCD+TV&subtypecode=&cmssubtypecode=&model=LA32S81B&filetype=UM&language=&LSSI=/in/module/ssi/left/lmenu_tv_sonomatrenz.sec&RSSI=/in/module/ssi/right/rmenu_tv.sec
and download it. I think Samsung refers to it as Teletext. Instrucitons are on page 31 of this manual.
Good luck.
Anonymous
  • 1142 Answers
  • Posted on Apr 23, 2008
SOURCE: Samsung LN-T4061F
To view the captions, all you have to do is turn on the decoder by following these simple steps:
  1. Access your TV menu screen using your remote or by pressing a button on the face of the TV.
  2. Select the closed captions heading. Several different caption options may appear.
  3. Select the "CC1" option.
  4. Exit the menu.
Closed captions should appear within approximately one minute of adjusting this setting. If they do not, review this portion of your television's operating manual or contact the manufacturer of the television set.
Public Television stations do not transmit Closed captioning
Anonymous
  • 217 Answers
  • Posted on Jul 20, 2008
SOURCE: Can't remove the Closed Caption on my Samsung
try putting it in the air channel mode and then see if you can access through menu
Anonymous
  • Posted on Sep 08, 2008
SOURCE: Closed Caption
Yeah, I'm now believing it's the tv. The captions on the other tv in the house work great. My samsung is only 2 yrs old. This model was 1080 i...Kinda of costly. Still no solution???? CR. LEE
How do i get captions for netflix streaming on samsung series 7 tv?
Is your Netflix being streamed from a box, or is the app built in to your TV. Either way, you would have to go into the user menu of the Netflix app for closed captioning. Not the TV menu. Hope fully this has helped. Try this link. https://help.netflix.com/en/node/372
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
1helpful
3answers
Samsung LN-T4061F
  4. Exit the menu.
Closed caption
If you have cable or satelite receiver the cc must be set up properly in the receiver. If just using and antenna or cable direct to tv then make sure the cc is not set in the wrong position.
2answers
Closed Caption won't turn off
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
1helpful
Closed Captioning
Does this happen with a HD cable box and does it happen with a DVD or VCR playing on it?
3answers
Closed Caption
closed caption depends on your tv stations. If a tv station does not support providng closed captions, then it will not really show closed captions. Closed captions depends really on the feature of a tv station
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
