GE Microwave Profile Spacemaker JVM1660
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
SOURCE: GE Profile Spacemaker 2.0 Microwave
If
it goes dead or blows the breaker or GFI when you plug it in or open or close
the door, then there's a problem with a door switch or door switch
mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door
switch or mount trouble can be caused by slamming the door or by
opening the door while it's cooking without hitting the Stop pad first.
There
are plastic mounts inside the microwave which hold the door switches
and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes
it's a broken tab on the switch holder, allowing the switch to rotate
just out of position. Other times, it's a broken tab on the switch
holder, allowing the switch to rotate just out of position. This tab
can be hard to see, since it is under the bottom edge of the switch.
If
you or someone you know decide to look into it, we have critical
information on safety, disassembly and door switches at our site, and
our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also
be a "mini-manual" hidden inside the unit behind the control panel or
hidden on the left side behind the grille, which is very helpful when
troubleshooting & testing.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Broken bezel/trim on door of GE Profile Spacemaker XL MICROWAVE.
You need to call GE customer care and order the trim you need. Make sure they will ship the replacement guide with the part. Before you do that however, carefully inspect the door to see if the old trim can be easily removed. This is important! You must determine that the door/gasket will not get out of alignment in the process. If this happens, dangerous microwave energy can escape.
Ray
SOURCE: I have a GE Profile Spacemaker XL Sensor Mod # JVM
You're usually better off just replacing the bad parts instead of the whole door.
If so, you can separate the door panels (as shown in the attached photo) then you can replace separate parts.
You can't remove the handle without doing this.
You can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Testimonial: "Although I received this solution after I had called in a technician and paid $100, your instructions were right on and exactly what he did. Doug"
SOURCE: GE JVM1660 spacemaker XL microwave
If
you gently push up on the door latch heads (hook-like devices sticking
out of the door)
there should be spring tension. If they just flop right up, the spring
is off inside.
Normally the problem is
not the spring, but a broken
spring mounting tab on the door latch head (hook) assembly or the inner
door panel.
If it's the door panel,
it's usually easier and cheaper to use epoxy and some kind of hardware
to fashion a new spring mount.
The door latch head
(hook) is easy to replace or repair if that's the issue.
You can find
model number here.
We have critical safety
& disassembly info at our site.
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that
We're
