Bought a used 4750e. The right sided paper guide of the fax input is broken and the fax document tends to slide off center when it is being drawn into the machine. Can this guide be replaced or repaired?
Also, it seems that you really have to slide the fax document far down into the input slot before the machine will catch it, and when it does, it will occasionally pick up several pages at once which causes the final fax transmission to be missing several pages. Any suggestions?
Thanks, Ken
Lets start with the paper feed problem. You need a new paper feed roller to pull the paper in when it should. You need a new seperation pad to prevent multiple pages from being fed at the same time. you will have to look at your machine to determine which parts are needed. here is a link to a company that I do business with. You can find the trays here also.
http://www.precisionroller.com/manufacturers/brother-intellifax-4750e.html
