Question about Janome Sewing Machines
JS1004. Can I drop the feed dog for embroidery?
  • Janome Master
  • 12,731 Answers
    Top Expert:
  • Janome Master
  • 9,098 Answers
Dropping feed dogs janome model 662 Unsolved Problems ...
www.fixya.com/unsolved.../dropping_feed_dogs_janome_model_662
How to drop feed dog on a janome 11000 sewing machine? ... Jan 21, 2014 'Sewing Machines ... Janome js1004 - can I drop the feed dog for embroidery?
Free Motion Quilting: My feed dogs don't drop
www.generations-quilt-patterns.com/free-motion-quilting-my-feed-dogs-...
What can you do to do free motion quilting without dropping the feed dogs? ReplyIf there ... Your feed dogs work to pull the quilt straight through the sewing machine. No problem ... Sewers use this needle for free motion machine embroidery.
How do I lower the feed dogs on my sewing machine? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Posted on Jan 17, 2016
Anonymous
SOURCE:
Anonymous
  • 323 Answers
SOURCE: janome 8000 memory craft embroidery/sewing machine
on the backside of your free arm there is a small lever which can be moved to lower the feed dogs.
When you want them back up move the lever the other way.NOTE!!
They will not go up until the machine has made one revolution.
sewman7
Posted on Jun 04, 2008
Anonymous
  • 3 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
Anonymous
SOURCE: janome mermory craft 8000 drop feed dog
I hate to sound dismissive but: read the manual. Duh. It is not as written above: drop dog........
The feed dog is the toothed pieces in the sewing machine deck, under the needle, which move the material away from you when you push the operating pedal.
Dropping the dog - ie making it inoperative - (see manual for how to on your machine) means the material has to be propelled by hand under the needle. This is especially good for freehand machine embroidery as it means you can move the material in any direction whilst sewing.
It can be easier to freehand embroider if your material is fixed in to an embroidery hoop to hold it flat while you work.
Posted on Apr 24, 2009
Susan Ellen
  • 6 Answers
SOURCE: Feed Dogs on Janome 1600P
I recently purchased a Janome 1600P-DB and in order to do free motion quilting I had to cover the feed dogs with an index card. I also cut a small section out of the card to allow for the thread and needle to move freely. Standard tape was used.
Posted on Oct 21, 2009
Anonymous
SOURCE: I have a janome 1600p. how do i drop the feed dog
there is a little metal plate that fits over the feed dogs, this is what I am using
Posted on Dec 26, 2009
Janome JF1004 - Lowering the feed dogs
Consult your owner's manual on page 30. Your machine requires an accessory called a "darning plate" that covers the feed dogs.
Janome JF 1004 Instruction Book Page 32
Jan 17, 2016 | Sewing Machines
When the embroidery unit is on the machine the "the feed dogs are raised lower them" comes on when I go to the embroidery edit or embroidery on my lcd screen and the feed dogs are down.
The problem you've explained isn't totally clear. I'll try to give help on your problem.
On embroidery machines the feed dogs are suppose to be down while operating in the embroidery mode.
When you change programs to embroidery the sewing machine recognizes this mode and automatically makes the feed dogs go into the down position.
If you are attempting to operate embroidery and your feed dogs don't go under the plate then: Try the switch that is under the storage unit and switch it to free arm.
Aug 25, 2015 | Sewing Machines
How do I lower the feed dogs foR free motion embroidery. I have a jANOME harmony 2039
Look on the back of the machine behind the bobbin area. See if there is a slide switch. If not, your manual will tell you how to drop the feed dogs. If you can't drop them, you may have gotten a neede plate that will cover the feed dogs so you can do free motion embroidery and quilting.
Sep 16, 2014 | Janome Harmony 2039 Mechanical Sewing...
Do feed dogs drop automatically on SE-400 when embroidery unit is attached?
Yes they should unless the tab on the middle of the embroidery unit is broken.
Jul 31, 2014 | Brother SE-400 Sewing & Embroidery Machine
The feeder dose not feed
there is a switch on the back of most machines behind the feed dogs that allow you to drop the feet for embroidery, you have to switch it back to raise the feed dogs back up
Mar 04, 2013 | Brother PC-8500 Pacesetter Embroidery &...
Every time I hit the start button to perform embroidery, the screen tells me to lower the feed dog - even though it's already down. Is there a way around this?
the sensor must not be working. I thought the 9000 lowered feed dogs automatically when embroidery option is choosen anyway. There is a manual as well as on screen drop feed dogs method for this machine
Jan 13, 2010 | Janome Memory Craft 9000 Computerized...
Are feed dogs supposed to be up or down w/ embriodery unit?
The embroidery carriage automatically lowers the feed dogs when put in place
Dec 01, 2008 | Brother SE-270D Computerized Sewing...
Janome mermory craft 8000 drop feed dog
Oct 26, 2008 | Janome Memory Craft 9000 Computerized...
Sep 20, 2008 | Sewing Machines
Janome 8000 memory craft embroidery/sewing machine
sewman7
Jun 02, 2008 | Sewing Machines
Sewing Machines Logo
304 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Thomas F. Schneider
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
