Has to be calibrated on a rolling road with the correct software ,or you have the wrong size tyres fitted ,they are low profiles making the wheels go round faster in relation to the speedo calibration
Your saying when you come to a stop,and want to take off and then it out no where goes as you try to acclerate.? Of course it neither one of them 2 things of concern first it sounds like you are low on transmission fluid.you need to check the transmission level if it is low and or doesnt register on the dipstick then what you have describe is the problem low on transmission fluid. Here is how it works when you have the appropriate level transfluid is sufficient to move the car.when your low its not enough fluid to engage the gears and when you step on the fuel pedal it forces to fluid to shift thcar and this is bad on engine and transmission, so check the level. Just for now make sure you have the appriopriate level
Check the fluid level in there. If it was low for an extended period, change fluid. Whining is often caused by low fluid level, but is also a symptom of internal wear. If fluid change does not help, it needs to be rebuilt or replaced.
you mean 70-80 kph? because in mph that is very fast! check your thermostat, and if its not a problem with the thermostat sticking , it may be a problem with your water pump
Hi. It can be tricky. This is normally a dealer setup before the machine reaches you.
You will need level buttons to switch between the 3 levels. do you have these?
You should program the other 2 levels with product types the same as first level, so if there are departments on L1, then put depts on 2 and 3.
I don't have the programming manual for this model, as we have the SE series over here and it is not quite the same. If you have a manual in electronic format that you can send, I'll look through it for you. Otherwise, I can only give pointers.
That is normal,If you do the same speed in 4th gear the rpm's will almost double.
The rpm's will repond faster in a manual than an automatic.
In a manual the engine supplies the power required directly to the gear that you have selected thus the engine rpm's will increase or decrease as needed.
