HP PL4260N 42 in. Plasma HDTV Logo
A
Anonymous Posted on Jan 04, 2014
Flickering picture - HP PL4260N 42 in. Plasma HDTV
Picture from Cameras flickering
No 'make model (what it is). 'Drv'??
Replace or repair whatever went 'pop'. A resistor or capacitor or even IC has failed.
Dec 19, 2022 • Cameras
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
Picture comes on but it flickers alot
check the simple things first: does it do it when using a DVD player or Blue Ray hooked to one of the rear audio/video inputs?
Picture Flickering
The sony tuners have been known to get intermittent, it might be a bad ground where the tuner connects to the main chasis, If the problem is in the tuner itself it will be most difficult to resolve since the connections are so small and compacted together.
Good luck
3helpful
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
ITC222 - RGB flickers using Tuner
its the Tuner rf gain voltage or AGC not set properly.
PIcture Flickering
you may have a convergence problem. need to replace the stk 392-040 2 eq..
1helpful
2answers
Screen/Picture Flickering
alo all..
i got problem wif my TV... sony wega trinitron 29inch..
- last 2 night... the TV @ screen slowly lost color for 2-4second... and after that it suddenly turn off for 5-10second and turn back on itself. the led blink 3-5times....
what the problem to my TV?
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
