Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
You need to mix 2.6 ounces of 2-cycle oil (NOT motor oil) with one gallon of fresh gas to get a 50 to 1 mixture. Most 2-cycle oil is sold in small bottles this size and have directions on them to get the correct mixture.
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual": This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline. Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use. Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US). Do not use automotive lubricant or 2-cycle outboard lubricant. NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period. PREMIUM EXACT MIX (50:1) GasolineLubricant 1 gallon (US) 2.6 oz. 1 Liter 20 cc (20 ml) If properly adjusted your blower will operate fine on 50:1 regardles of what the manual reads. HTH Lou
Yes it will use a fuel mixture of 40:1(3.2 oz of two cycle oil to 1 gallon of gas). Any fuel sitting over 30 days now is considered bad fuel. All the manufacturers schools this year and told us this. We are finding it to be true. Good day.
