Heating & Cooling Logo
Lisa Mesaris-Killough Posted on Jan 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung trouble shooting
Samsung led smart tv Model: UN40EH5300FXZA no picture just sound
Stephen Littles
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 17, 2014
Stephen Littles
Contributor
Level 1:
Answers
Questions
Helped
2277
Points
0
Samsung Frigidaire RB195 twin cooling system not working
  • Jack Morgan
    Jack Morgan Jul 07, 2014
    my samsung ue46d500 conked out on me and now all i can get is an intermitting flashing green light on my standby button
vasilebaran
Level 2:
  • Expert 90 Answers
  • Posted on Jan 12, 2014
vasilebaran
Expert
Level 2:
Answers
90
Questions
0
Helped
28608
Points
101
Try in av mode with an external signal (like a dvd or homecinema)and if it work you must to change the mode function(maybe is select european mode or something else)
2answers
My samsung led tv, when i turn on red light blinks 6 times. no display, no sound. Tried replacing power board, main board and tcon board, all of them seems to be fine. What else could be the problem.
You have at least one bad LED in the panel and its shutting down the power supply...for future reference a bad Tcon will not cause loss of sound only affects picture
I have a Samsung 40" LED tv that has sound but no picture. You can see an image if you shine a flashlight on the screen. I see no backlights when I take off the back.
Hi!
Check the backlight circuit, but first, check the power supply of the blacklight circuit, does it feed the backlight circuit or not. If not, it's the power supply circuit, if yes, check the backlight circuit itself, and if it works, check the backlight themselves, the led. Good luck,
Serge.
1helpful
3answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
Here is what to check when your TV is turned on, power light is ON, but no picture is seen or sound is heard:
1 - Be sure the component you are using (Xbox, Cable, SAT, ROKU) is turned ON.
2 - Check to be sure all cable and cords are securely connected to the TV inputs and component outputs.
3 - Make sure you are on the correct input as some TV's will show a black screen if there is nothing connected to that input.
4 - Unplug the input you are trying to use from the TV (such as an HDMI Cable) and plug it back in.
5 - Check for signs of damage on all cords and cables from the TV to all components.
6 - Make sure the TV is not in ENERGY SAVE MODE, press the button on the remote control to go back to normal mode.
7 - Unplug the TV for 10 minutes to see if there was a temporary one time issue with the TV.
8 - Disconnect the TV from power for 2 minutes, then when plugging it back in PRESS AND HOLD THE POWER BUTTON ON THE TV FOR 10 to 20 SECONDS to try and force the TV to reset.
9 - If after checking all these different issues, you may have a Faulty Power Supply Board, A Bad Capacitor on the Power Supply Board, Loose Wire Harness, or Loose Ribbon Connector in the TV itself.
10 - Most likely when a TV has the power light ON but NO PICTURE and NO SOUND, it is the Power Supply Board that has failed.
BTW, here are solutions for you to play iTunes movies on Samsung smart TV
It has sound but not picture, please help
Hello. Repairing your own TV isn't something I recommend. You risk injury, and could cause more damage. If you still want to proceed, remove the back of the TV. Unplug the cable between the Main board (the one the inputs connect to) and the Power board (the one the AC cord plugs into). Then plug in the AC cord. If the backlights come on, you probably have a bad Main. If they don't, it's likely the panel, which is expensive.
Top Samsung Heating & Cooling Experts
jws1013
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
