Lenovo Yoga IdeaPad Ultrabook 13.3" Touch-Screen Laptop - 4GB Memory - Silver Logo
A
Anonymous Posted on Jan 26, 2018
Screen keeps messing up with lines and breaks throughout the screen at random times
My touch screen keeps randomly getting lines and weird cracked looking type marks randomly on the screen sometimes. I will exit out of the tab and the other tab will be fine. or if I am scrolling down, there will be a weird block that will come up... I don't really know how best to describe it...
Carlos L. Glez
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Lenovo Master 419 Answers
  • Posted on Nov 03, 2018
Carlos L. Glez
Lenovo Master
Level 3:
Loyalty:
Answers
419
Questions
Helped
79907
Points
1953
Hello, I believe you have a problem with the firmware, different factors can give you the same error; I recommend to do a factory reset (remember before to do back up in the external memory or cloud), then if still persist the issue, you can contact the customer services to get more support. https://support.lenovo.com/us/en/?menu-id=Technical_Support
  • Carlos L. Glez
    Carlos L. Glez Nov 03, 2018
    Thank you for you opinion.
  • Anonymous Jan 19, 2019
    Lenovo Yoga IdeaPad Ultrabook 13.3" Touch-Screen<<< this does not show up at lenovo support page,why? well its wrong model stated.
    after a hard power reset fails.
    the fist thing on an laptop,, pad
    is batteries, replace them.
    the bios dies not leak out (firmware)sorry.
    the lines issue to me sounds like the notebook was dropped (damage)
    for sure it needs service,
    lenovo has the worse laptop index page in the business.. good luck finding it...https://pcsupport.lenovo.com/us/en/
3 Related Answers
Anonymous
  • 14 Answers
  • Posted on Sep 15, 2009
SOURCE: keyboard locks randomly after login
Sound like you might have a virus - try running antivirus program - such as Avast or Antivir - which is free.
If that doesn't work, then try doing a System Restore - if that doesn't work, then do a System Recovery complete re-install - but back up your pictures and documents first as you will lose everything and you'll be starting over again fresh.
Fred
Anonymous
  • 1481 Answers
  • Posted on Jan 06, 2011
SOURCE: Randomly one day my computer screen looking like
Graphic Card is corrupt so no display on the LCD screen and the display on PC monitor is fine
Change the graphics card
Anonymous
  • 663 Answers
  • Posted on Jun 30, 2013
SOURCE: My laptop (lenovo g560) randomly shut down.
Try scanning your computer with radarsync to know which drivers are out-of-date. It has something to do with the device drivers for sure. Update the drivers using RadarSync.
If it still not going to fix the problem then check if there's a sign of overheating after it shuts down. You might want to get it opened by a technician so that he or she can clean the air passages and fans inside your computer.
David
Alpine iva w205
Sounds like a problem with the actual touch screen itself. Kinda like an iPod touch. If the screen gets smashed ( like if your kid puts it in their back pocket and sits on it :) . That can be replaced but its a fairly costly item and is a reeeeeeeeeal pain. Not to mention if the new touch screen gets so much as a hairline crack in it ( some you can't even see ) it won't work. Hope this helps.
1helpful
My calculator is a mess! It types random numbers at random spots and there are black lines on the screen!! Help!!
Sorry you're gonna need a new one. The hardware and software seems to be... well MESSED up.
7helpful
Screen randomly messes up
I had the screen problem, simplest fix, that I found was to simply hit the camera button on the side of the phone when it is turned on. It somehow resets the screen. It works most of the time on the first time.
1helpful
2answers
My screen goes white randomly
There is something wrong in the inside of the part that slides up.
The problem is only going to get worse.
Xbox 360 randomely gets a black screen
Well here's the problem the towel trick. Ok the problem with the 360s for the most part is small cracks in the solder which causes a bunch of problem from rrod to this. The towel trick heats up the 360 enough to get the solder flowing again thus providing for a temporary fix. The problem is the solder goes places is shouldn't, thus towel trick ends up messing the 360 up more then it helps. My advice send it in, hopefully you still have the warrenty.
1helpful
2answers
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
