The mower runs full power mowing quits after a few min. no power doesn't turn over then starts after awhile. Will run for a few min again.
Ran fine last year until starting this year
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
If it is not turning over then it sounds like there is a problem with something either electrical or the ignition. Usually this problem is a fuel related issue. Especially after sitting over the winter. But I will admit that I am wrong sometimes and it can be electrical or the ignition. But letme know how the gas goes first and then I will help you diagnose it from there if that is not it
to jgwhomeequip I thought the same thing but there is no power to crank the engine as far as the starter engageing the engine goes. I turn the key and get nothing until it sits for awhile the it starts up again I will try the new gas but why won't it turn over
Michael1457
I have also changed the Ignition Delay Module, but have not tested it yet, but still it has the flashing battery charge light.
