Samsung SC-DX103 DVD Camcorder Logo
A
Anonymous Posted on Jan 03, 2014
Download dv media pro - Samsung SC-DX103 DVD Camcorder
1 Related Answer
Anonymous
  • Posted on Aug 21, 2009
SOURCE: DV Media Pro 2.2 defective - download impossible
j'ai pas pu installer mon camescope samsung car mon driver DV media pro2.2 sur cd est deteriore
2helpful
I need canon xha1 service manual
http://downloads.canon.com/cpr/software/video/XH_G1_A1_manual.pdf
tip
Canon XHA1S Manual Download
Download Canon XHA1S HD Video Camera Manual
Would you like to review the features of the Canon XHA1S HD Video Camera?
Have you lost your Canon XHA1S HD Video Camera Owners Manual?
Would you like a digital, searchable, pdf version of the Canon XHA1S HD Video Camera Users Guide?
Follow this link
(& click FREE) to download a pdf version of the Canon XHA1S HD Video Camera documentation.
I hope that helps.
2helpful
Why can't I get video recorded on my DXG-506V Camcorder to play the video on my computer (plays audio only)? I am running windows xp-pro with usual attachments.
videos recorded on your camcorder is in mpeg 4 format so you need a codec for mpeg 4. ro download vlc media player and play your videos from there.click here to download free vlc media player.
Tdk sony dvm60 miniDV tape not playing in final
HI please check your easy setup in tyhe fcp and set it as pal or ntse dv and should get the video in
4helpful
3answers
Need software for Samsung DVD Camcorder, free. Please.
"DV Media Pro" from Samsung
http://www.samsung.com/us/support/download/supportDown.do?model_nm=SC-X205L&mType=DR&vType=L or http://tinyurl.com/rxzcsf
Also, if you're planning on editing the video in another app, it seems like you might need this:
http://handbrake.fr/
2helpful
3answers
3answers
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
NOEL
NOEL
 Grubhead
Grubhead
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
