Need instruction manual/schematics for replacing 2005 kia rio driver side rear wheel bearing. i've got the wheel/hub/bearing off, not the inside ring to the bearing. i need to know how to replace it .. as i do not know how ? because well the parts were all goulashed up inside the hub... thanks for your time and consideration. respectfully e.m.w.
Clean all the grease if there is any out of the hub, turn the hub over and using a drift and hammer strike the shell from the back edge working around the shell as you go, should not take too much to remove it but you will need a bit more than a tap with the hammer.
Hope this has helped you
Thanks, the inner ring to the bearing is stuck on the axle, which we are trying to remove now, not the funnest thing ive done ,
thanks again
emw
thanks again
emw
How to replace carrier bearing on kia sorrento 2005
