Paper will not feed
Check inside the machine at both ends of the cartridge carriage path i.e. far left and far right. Check for scrunched up paper and note, if it is there, it will likely be black with ink. If found please remove. Next take the back off the machine (there is usually a removable plate there to get to paper jams) and remove anything you find there. Also look right through towards the front and see if the little drop down paper feed sensor arms are all visible and swing freely. If not, fix them as you can. Once you have done these things, put everything back together and leave the printer powered off for 30sec. Power it up and see what happens. If you are still no go, either take it to a service tech or check to see if your insurance covers printers being beaten to death with a 4 pound hammer.
Epson or HP? You posted under Epson, but you said you have an HP.
