Question about Lenovo IdeaPad Z560 Notebook
Power chord not showing charging symbol - Lenovo IdeaPad Z560 Notebook
I have a fire hd6 and charging the battery it shows to be charging with the symbol in the battery but the power keeps dropping and does not charge
Make sure you're using the charger that came with it. Otherwise you may not get enough power to charge. Especially if you're using it while trying to charge.
Mar 29, 2017 | Symbol Computers & Internet
My Blu studio 5.0 power button is missing and I can't power it on.Can someone please help me?
Hello Melissa, sucks about your phone. They sell replacement power keys online for usually 3-5 bucks. Something you can try though, plug your phone in to a charger and let the loading/charging symbol come on. After it comes on, pull your battery out of the back of it but leave the charger chord in. Wait about 15-20 seconds and then put your battery back in. It may take it a couple times of repeating that but it usually comes on after doing so. If that's not working, do the same thing but unplug the charger and then put the battery back in and plug the charger in at the same time. Let me know if neither work and I can try and show a different way if needed. Good luck!
Jun 18, 2015 | Blu Cell Phones
My battery is fully charged but there is no power
The power on the main board may be fried or you just aren't really charged. Check your ac adapter chord these can go and not charge anything replace ac chord and battery and if that isn't working it's probably your motherboard and then it's new laptop time!! Exciting isn't it.
Apr 18, 2015 | Computers & Internet
Power chord must must moved continually to show charge
Yes, this is common, if the power cord at the connector is flexed continually then the metal fibres in the cord will break due to metal fatigue.
You can cut off the connector away from the break and fit a new connector on the cord, make sure the the wires are soldered correctly to provide the correct polarity at the connector.
The problem could be at the laptop where the connector plugs into the laptop's power socket. It could have a dry solder joint or the socket is faulty. This requires dismantling to repair.
The HP warranty would cover the normal warranty period and would not extended for worn parts.
Apr 15, 2009 | HP Pavilion dv6000z Notebook
Power chord
get a power cord as it would be less expensive because if the connector on your system is faulty you may have to spend a lot of monet
it happen with the power cord that they go gad
so don'y worry about that
Jun 10, 2008 | IBM ThinkPad T43 Notebook
Dell 620 Battery Issues
Chances are pretty good that your battery just needs to be replaced. Over time all rechargeable batteries loose their ability to hold a charge. It's also possible, but less likely, that there could be an issue with your AC power adapter or the charging circuitry inside the laptop.
Best bet would be to find a similar laptop with a battery that does charge and switch. If the problem follows the battery then you need a new one.
Dec 19, 2007 | Dell Latitude D620 Notebook
Lenovo IdeaPad Z560 Notebook Logo
16 people viewed this question
Top Lenovo Computers & Internet Experts
Ekse
Toby Lee
Toby Lee
Sunny Solanki
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
