Question about Kodak EasyShare Cameras
Kodak EasyShare Z712 IS will power on but shuts right off
When I turn on the camera it will go on but then right off. I have replaced the batteries and that doesnt seem to be the problem.
6ya staff
SOURCE:
Anonymous
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
Posted on May 26, 2009
Anonymous
  • 89 Answers
SOURCE: My Kodak EasyShare Z712 IS problem is with the
I've had the exact same problem with mine. My wife was ready to buy a new one, but I didn't want to giveup the nice optical zoom on the Z712 IS. Checking out the web and a friend of ours with the same camera, it appears to be a common problem. My last time to try the camera, I took 19 pictures on brand new batteries and they died. The Kodak site doesn't really acknowledge a problem with the camera, but I found the latest firmware (1.06) and just walked around the house taking pictures with flash. At 25 pictures, I'm still going strong. Definitely worth a try to see if it fixes your problem: http://www.kodak.com/global/mul/service/downloads/DownloadFile.jhtml?locsvcsEntryPath=10807&product=EKN033025&operatingSystem=windows_xp&lang=en&type=firmware&downloadId=dln00179_file1&variant=false&pq-path=14091
Posted on Jul 16, 2009
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: Have Kodak easyshare Z740 camera, turn on and goes
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 15, 2009
leepania
Pania Lee
  • 1099 Answers
SOURCE: My Kodak EASYSHARE M1063 camera won't turn on
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 13, 2009
leepania
Pania Lee
  • 1099 Answers
SOURCE: i Have the Problem with my Easyshare Z712 IS Batteries
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
Posted on Dec 03, 2009
My m590 doesnt turn on
Faulty Battery contacts or defective battery.
Oct 27, 2012 | Kodak M590 Digital Camera
Red light by the battery is blinking n doesnt turn on
Hi bklynzrealis,
Seems that you battery needs charging, if you already did recharge the battery then the battery needs replacing if the red light blinks after charging.
I hope this help.
have a nice day,
mvincnetc
Jul 12, 2011 | Sony Cyber-shot DSC-W200 Digital Camera
Every time i turn my camera on it shuts itself right back off...i've tried charging it and that doesnt fix the problem....
hi;
try to use another new battery, i think its a power problem.
the current of the battery is poor to turn on the camera.
Oct 30, 2010 | Kodak EasyShare M1033 Digital Camera
My sanyo camera turns it self off right after i turn it on. How can I fix it?
mine has started doing the same , the battery is showing charged , though when i have it plugged in at the charger it doesnt switch off., am thinking its a battery issue and will be changing battery,
Aug 02, 2010 | Sanyo Xacti VPC-T700 Digital Camera
Emprex DSC5100Z camera doesnt turn on.
Here are the steps:
clean cloth.
If issue persists camera needs to send for repair,visit www.emprex.com
Thanks.
Regards,
Neerak21
Sep 25, 2009 | Emprex DSC5100Z Digital Camera
Light meter on my vivitar v335 ( film) doesnt show up
If there is supposed to be one in the camera, you may need to install/replace a battery.
May 29, 2009 | Vivitar V4000 50MM 35mm SLR Camera
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
How to turn on the Camera?
you might have the battery in the wrong way, make sure it is in correctly
Sep 17, 2008 | Casio Exilim EXZ75 Digital Camera
Digimax A7: When I turn it on it turns off.
It seems i have the same problem...although my batteries do charge, and i can take pictures. But when I play them back It does this beep beep beep and shuts off and the lens doesnt always close. It's really pissing me off
Dec 20, 2007 | Samsung Digimax A7 Digital Camera
Cameras Logo
285 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
