Compressor works,defrost cycle works,freezer will freeze but a day later it is not below freeze temp.is this the timer/
SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
SOURCE: Clicking noise from compressor and fan runs 24/7
check the grounds to the ref. also check power to the ref. but it sounds like you have a floating ground the only thing else to mke comp.cycle is the relay which is on the comp. itself
SOURCE: Kenmore 596.72913200 Refrigerator is Warm,freezer not freezing
The frost on the back wall of the freezer with a new timer installed indicates that the problem is beyond the timer in the defrost circuit. In this circuit you have a defrost heater and a defrost thermostat. One of those two is your problem.
If you have an ohm meter available and have the knowledge how to use it you can access the heaters by removing the back panel wall of the freezer section. Disconnect the heaters from the circuit and read the meter for continuity. If you read Ohms through the heater(s) your problem is in the thermostat.
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
SOURCE: My Kenmore refrigerator defrost drain freezes over.
There is a heat probe kit available to help prevent the drain hole from freezing shut. Part # 819043.
