could lack of house pressure +leaky inlet hose have an effect like this on the pump.could lack of house pressure +leaky inlet hose have an effect like this on the pump.
You can't post conmments that contain an email address.
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
You can purchase a complete unit from Grainger for about $210.00. Their part number is 6UZP8. And in most cases they are located locally, so you can pick it up and be back in business quick. The pump is actually manufactured by Excell Power, so my thought would be replace the pump and then try to find a rebuild kit for the bad pump and try to rebuild it as a backup. Hope this helps.
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Leaving the engine running for more than two minutes without releasing pressure trigger causes aluminum pump to overheat and causing damage to the purmp, resulting in sudden low pressure. (see page 9 in manual)
The pump might be binding against the motor, causing the pump to overheat and temporarilly "seize up" and shut the engine off.
After cooling down for a brief period (5~10 mins) the engine can usually be re-started, but the overheating problem will keep coming back.
This happens when the pump either wasn't seated against the engine properly during it's initial instalation, or the pump housing wasn't machined properly and the PTO shaft is trying to drive the pump at a slight angle = excessive friction = overheating.
Try this:
1) Loosen the bolts that mount the pump to the engine just enough so that the pump can be wiggled slightly.
2) With the engine power switch in the "OFF" position, slowly pull the recoil starter rope so that the engine / pump completes about two revolutions. This helps to align the pump surface with the engine.
3) Lightly snug the pump mounting bolts in a criss-cross pattern, then slowly pull the recoil starter rope again to ensure that the pump isn't binding.
4) Finish tightening the pump mounting bolts in the criss-cross pattern (approx. 21 foot pounds torque).
The entire process should take you roughly about 10 mins from start to finish.
If this doesn't remedy your problem, then try running the engine for 20 mins with the pump COMPLETELY removed so as to isolate the components.
The 3 psi is caused by a failed transfer pump. The problem the loss of could be the VP44 injection pump. This pump should be run at min 7psi. I had the same fuel pressure problem. I replaced my stock transfer pump with a FASS DDRP from www.usdieselparts.com. The stock pump is over $200 to replace and will fail again, sometimes right out of the box. The DDRP will supply about 15psi to the pump and is simple to install. I hope this helps.
check pressure on fuel rail using propper fuel pressure gauge if its not to manufacturers specifications replace fuel pump if it is to manufacurers spec then replace fuel pressure regulator on the fuel rail thanks good luck with projects
