LG Flatron 776FM 17" CRT Monitor Logo
Sheila Carter Posted on Jan 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have HP w2338h sound won't work
Sound wont work
ernest
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 113 Answers
  • Posted on Jan 04, 2014
ernest
Expert
Level 2:
New Friend:
Cheetah:
Answers
113
Questions
Helped
30552
Points
242
Download sound drivers from the internet for your Model Hp ,there are no sound drivers or sound drivers got faulty due to virus or update.
How do i mute the hp w2338h
Open Control Panel and from there, click "sound". Under playback, you can see the audio devices connected and you can right click on them and select enable/disable.
Sound doesn't work
First thing first, check cable and sound card with another speakeer system. most of the time even if the sound card show in the device manager it can be faulty. then begin work from there.
if you found that the previous step work and the monitor does not work, you may require to change the sound card in it. at this point I would use external speaker set.
I have HP w2338h moniter .Its screen show menue screen again and again .
Hi hsaiyed,
appear. You can do different function you want for your monitor to do such as turning the menu off. Observe if the button is working properly, if it is stuck the "menu" on screen won't go away.The buttons are either on the right hand side facing you or under the panel.Buttons go bad due to improper use. If it is bad you have to replace the control panel.
Hope this helps.
Thank you for using FixYa.
Just moved & set up my computer with HP w2338h monitor with built-in speakers, it does not play sound. I've restored factory settings, checked volume & mute, turned off/on, double checked all...
Try the following:
  • Right click the speaker icon in your icon tray > click playback devices, see if you can see your monitor there as an option, and if so, right click it and click "Set as default device"
Hopefully that helps!
My hp w2338h monitor randomly goes to sleep only when I play games. I have turned set hybernation to never in power options, updated all drivers and this still happens I have also plugged in another...
ok , we've answer that question here , vast endless times.
all old monitors before magic year 2010 even go to sleep
all by them selves to save the pathetic, CCFL tubes insid it.
so learn to use the monitors OSD screen.
push the menu button there(real button)
see that? now turn off sleep.
i will now read the manual to you.
3 seconds latter (manualsdir.com)
page 33
turn off the time and all sleep function INSIDE the monitor
amazing no? RTM still works in the year 2018...
https://www.manualslib.com/download/71500/Hp-W2338h.html
I have a HP w2338h monitor that goes blank
It is most likely a bad power supply... I have had aboit 4 diff monitors do this to me... most common is under rated capacitors in the internal power supply... some times there could be a black light going out witch causes higher current draw on the power supply ( witch can take out the caps, fusses, transformers ( caps and transformers when they get week and bad can cause the buzzing sound ( on some times with a radio near buy then the monitor is acting up with blanking out and buzzine the radio will pop and buzz as well witch is a sign that there is arching going on IE. caps and transformer are most common for that )))
hope this info helps
kc7wzl
2answers
I have the HP w2338h monitor. when i listen to
Hi there , Go to your PC settings , and Try turn Screen saver off , aswell as Sleep off... it is in your PC settings.
Good luck
No volume from hp w2338h monitor...only sound comes from headphones pluggedinto computer
check if the monitor speakers are the default speakers for ur computer.. to do so.. click Start.. then under start search type.. Sound.. and hit enter on this screen u shall be able to see various devices as speakers.. the one with Green check is the default speaker.. select Monitor and select Default below and thts it.. ur done.. for more info.. go to the following link from HP http://tinyurl.com/2fvjh7l
let me know if this was helpful to u.. regards, guru
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
