Copystar CS-2050 All-In-One Printer Logo
A
Anonymous Posted on Jan 03, 2014
Print mode error
Will print but not word document only attention light come on and registers print mode error
My 1300 hp printer still all lights on how to resolve problem
HP LaserJet 1150 and 1300 Series Printers - Understanding and Troubleshooting Control Panel Light Patterns This document explains how to interpret the light patterns on the HP LaserJet 1150 or 1300 series printer control panel. It lists the error conditions, describes the possible causes, and provides steps to resolve the conditions. Description of the control panel The control panel contains two lights and one lighted button. Patterns of light indicate printer status.Figure 1: Location of control panel c00007297.jpg 1 - Ready light 2 - Go button and light 3 - Attention light Figure 2: Light conditions c00007298.jpg 1 - Light off 2 - Light on 3 - Light blinking The following table explains the lights on the control panel. See "Status light patterns " below for an explanation of the light patterns.Light or button Description Ready light Indicates that the printer is ready to print. Go button and light To print a demo page or to continue printing while in manual feed mode, press and release the GO button. Attention light Indicates that a printer media input tray is empty, a print cartridge door is open, a print cartridge is missing, or other errors. Status light patterns This section describes the meaning of the light patterns. If a problem persists, see the flyer that came in the printer box for contact information, or click here to go to "Contacting HP support" below . Ready Light pattern c00007299.jpg Description The printer is ready to print. Action No action is necessary. To print a demo page, press and release the GO button on the control panel. Processing Light pattern c00007300.jpg Description The printer is receiving or processing data. Action Wait for the job to print. Continuable error Light pattern c00007301.jpg Description The printer is in manual feed mode. OR The printer is out of memory. Action The software controls manual feed. If manual feed mode is not wanted, change the setting from the printer properties. See the User Guide for information about changing printer properties. OR Take one of the following actions:
  • The page being printed might be too complex for the printer memory capacity. To continue printing, press and release the GO button. The printer might print a partial page, or the quality might be lower than normal.
  • Lower the resolution. See the User Guide for information about understanding print quality settings and changing print quality settings.
  • Add more memory. See the User Guide for information about installing DIMMs (HP LaserJet 1300 series only).
If the problem persists: Attention state Light pattern c00007302.jpg Description The printer is in an error state that requires operator intervention or help. The door is open, the media is out, the printer cartridge is installed incorrectly, or the media is jammed. Action
  1. Check that the printer cartridge door is completely closed.
  2. Load media into the correct input tray.
  3. Check that the print cartridge is correctly installed in the printer. (See the user guide for information about changing the print cartridge.)
  4. Check for any media jams and clear them. (See the user guide for information about clearing jams.
  5. Check that the left side panel is completely closed. If the left side panel is completely closed, open the left side panel and push the door sensor. Occassionally, if the left side panel appears closed, the sensor will still remain in the open position, generating this error. Pushing the sensor will shut the door tight, returning the printer to the normal mode.
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
The orange lights are flashing, is there something wrong?
Try:
1 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
2 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
1helpful
Printer Problem-Not printing at all.
Half circle = ready to print (when light is on )
! mark in a triangle = Attention light : Indicates printer media input tray is empty, print cartridge door is open, print cartridge is missing, or other errors. See Printer information pages for more information.
( light on means that there's an error )
piled circles = toner indicator (light on means toner ("ink") is low, needs replacement)
There's a help page for these light indicators, just in case other lights are / come on, see:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?cc=US&lang=en&objectID=c00230632&prodSeriesId=410622&prodTypeId=18972
Control Panel light indicators overview:
How do you turn off the in use/memory light?
This of course depends on why the light is on! If you had a fax come in and it is in memory, you will need to print the fax and clear the memory before the light will go out. The LCD Display should be telling you why that light is on.
1. There is a fax or print job in memory waiting to be printed.--> See steps below
2. There is a paper jam --> Open printer - Remove all paper - Close printer - press OK button
3. You are out of ink or the cartridges are low. - Change Cartridges
Solution: Printing reports and lists MX310
The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
2helpful
2answers
How can i get a fax from memory.
Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
LIST
REPORT
RX (Reception)
REPORT
7helpful
5answers
Printing problems Kyocera KM 2050
try setting the driver to KPDL mode in the settings section of the driver
Top Copystar Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
