Someone set the 2026 DVD player to s-video. The TV is older and doesn't have an s-video input. The setup menu won't show up on the TV so I can change the setting from s-video. How do I do it? I also want to change the channel from 4 to 3. How do I do it?
I recommend the obvious solution which is to plug it into an S-Video compatible TV, VCR or DVD player then change your settings. You could make it really for yourself if you want by looking for some software that you burn onto a CD which you make bootable and when you run it in the player it resets everything to factory default settings. But seriously make it easy on yourself and just plug it into an S-Video compatible device (TV/VCR/DVD, preferably a TV for ease, though it doesn't make any real difference). Best of luck to you anyway!
My TV doesn't have S Video which is why my TV doesn't acknowledge that's it's connected anymore. I need to set mine back to the factory settings of YPbPr. I'm trying to do it using the setup menu which I can't see, but either I'm doing it wrong or my remote isn't acknowledging every button every press.
