Neff B1432 Single circotherm plus Electric Oven Logo
A
Anonymous Posted on Sep 16, 2017
Oven timer "screeching"
Oven continues working but with a high screeching sound from the timer .have tried to juggle around the controls and occasionally I can get it to stop . Next time in use it starts again . My feeling is the timer has blown and I wonder if there is some way to disable it . If this was done , would the oven be able to continue on a manual on/off basis ? M. MacDonald
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Jul 06, 2008
SOURCE: U1721 Strange Problem
could be a clock fault - try bypassing the auto function on clock.
otherwise, check the terminal block where mains is connected. these quite commonly burn out
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Nov 25, 2008
SOURCE: Neff B1442 Oven -- Defective timer and clock
Hi.
Is it flashing AUTO, If it is and you can'y reset it back to manual, then you have faulty timer.
Hope this helps
douglas smith
  • 1462 Answers
  • Posted on Nov 29, 2008
SOURCE: Neff B1432 2002 Element blown
did you check the old element with a multimeter to make sure it is in fact faulty?
check continuity across the thermostat as well
Anonymous
  • 4 Answers
  • Posted on Jan 07, 2009
SOURCE: Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
Anonymous
  • Posted on Nov 14, 2009
SOURCE: Clock flashing OOO continously
I have same problem - the timer just blinks at me "0.00". I have tried every combination of buttons, can anyone help ?
Peter A
Beeps for no reason but no error code and oven works fine - a Whirlpool gold double oven
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
Read more :
How to Get GE Oven to Stop Beeping eHow
Oven "screeching " noise .
Yes it wil continue to work on manual basis
1helpful
I have a Fisher & Paykel OS302. The temperature and oven mode selects are dead, no LED display, no operation. The clock module is working. This happened all at once, I tried to turn it on and both...
This sounds as if the electronic clock timer is in automatic mode. It must be in manual mode for the oven to work. Turn the oven on and play around with the timer controls/buttons. When the oven indicator light comes on the clock is in manual mode.
Bottom oven not working, nothing comes on at all, though the display is flashing AUTO, and cannot change this as do not have manual. Thanks
It sounds like the oven is not working as the electronic timer is in auto. mode. It must be in maunal mode for manual oven operation. Turn the oven on. Muck around with the buttons on the timer and try all different combinations. This may take 5 minutes or more. When you do hit the manual mode the oven indicator light will come on and the oven will work.
Feb 15, 2011 • Ovens
While working near my Jenn Air Oven (Model JJW8527CAB) the function keys were possibly touched and the oven started displaying F7 error code and is continuously beeping. Pressing Cancel does not help....
Oven keeps beeping:
if Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
Read more :
Display is flashing0.00 and auto. oven won't work, took out circut breaker still doesn't work. when trying to reset the clock high pitch sound comes on and have to turn oven off at wall to stop
It will not work if it is flashing, the timer needs to be reset to manual
If it will not reset, then It sounds like the timer is faulty, try a different combination of buttons when trying to reset it.
Hope this helps.
Feb 02, 2010 • Ovens
Timer is making ticking noise cant turn it off.
My same oven makes a ticking sound when you tell it to start pre-heating the oven. The oven continues to make this ticking sound until you stop the oven and it completely cools down. This ticking sounds to be coming from the oven control panel. I have no solution, but I'm glad I wasn't the only one who had a problem with this ticking sound!
Jul 15, 2009 • Ovens
My jenn air dual oven timer, temp lights are going out
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by Briangem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF.
1helpful
2answers
F1 error on SS Amana Convection wall oven
The control panel has a design problem, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the panel out, and inspected it. I found a web solution that said to shim the panel out away from the housing slightly because it rubs on the metal housing around it and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried it, and it still did not work.....panel was still beeping. Mine seemed to be the timer control buttons that were going on and off. So, I took it out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off and looked at the control panel. It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and put the cover back on the board. It was still sticky enough to go back on. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo!
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
john h
Are you a Neff Oven Expert? Answer questions, earn points and help others
