What about with the key in the on position -do the warning lights and gauges turn on? That would mean the ignition switch has power and can turn on.
Any theft alarm activated, immobilizing the car?
Won't turn over- you mean won't start or the starter won't spin the engine over? If it won't start, ignition spark or fuel problem. If the engine won't crank, problem is in the start circuit- from battery to starter, and from battery to ignition switch to starter. Park/neutral safety switch is in circuit between key switch and starter.
SOURCE: My Excel has recently been broken into and the
you have to replace the ignition switch its broken a locksmith can replace it for pretty cheap around 60 bucks
SOURCE: the ignition wont turn back
Push in turn back all the way. You may have a lever u have to push or its not in gear all the way as in park.
SOURCE: i have an 04 grand
To beat security problems that turn off the starter, check out this link. http://vatspasslockpasskeysecurityhelp.yolasite.com/
SOURCE: 2002 f350 will not
ok well this is where you might be incorrect... either you have a 12 volt wire bleeding scross or you have a bad ignition switch. the run wire off the ignition switch is the only thing that will keep it running unless you have a remote start then of course that could keep the engine running. you might want to start by making sure the ignition switch is beaking the signal to the PCM.
