Hi. try to reset this unit by killing the power or unplugging the cord for 5 minutes. this will reset the control. if the control continues to beep after you reset, this will confirm control failure. you will need to replace the control board in this case.
Unit is not beeping. The unit does retain the correct time. it simply will not continue to display the time.
Had to treat it like a reset. With the clock display off, held that reset/start button down for several seconds and the clock eventually came back up without the START? prompt. Pure trial and error.
Good Morning, The touchpad on your oven may be failing. Often the buttons fail/short... and will beep as if theyre being pressed when in fact they aren't. FixYourBoard.com is able to test both the control board and touchpad, and if necessary replace/repair both parts to restore 100% oven functionality. Reach out to them by sending an email to [email protected]
