My daughter's zeepad will turn on but only to the screen that says "android". it will not get past this stage. When I hold the on/off button it will turn it on and off, but it will not get past the dark screen that says "android" that has the white line going letter to letter. I don't see any reset buttons or a way to access inside the unit to find one. What do I need to do to get it to fire up again and get to the home page so that she can use it again?
SOURCE: while reading my kindle screen went dark and the
You most likely need a new screen. If you're out warranty, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
SOURCE: Top portion of screen has
Try to hold the slide key for 15 sec. It will reboot your kindle. If black patch is not gone even after that, It's a hw issue. Screen might require to be changed. If it's in warranty Amazon will do it free. That's what i have heard.
SOURCE: i want to reset my daughters android tablet 4.0
To reset the tablet, you're going to have to do what's called a factory reset. To do this go into the settings, and look for tablet information. Under that it should contain a factory reset button.
SOURCE: Android tablet will turn on an make it to the word
I will try to help you solve this problem. First you may have pressed the on and off button and the volume button at the same time. This is no pig problem. It will come back on after a while without doing any thing or you can try rebooting it back on to factory setting. Mine did the same thing and when I just waited later it popped back on.
SOURCE: i cant remember pass word to my zeepad
I have tried to do all of that and everytime I click a link to download the firmware it comes up page not found.
