I have a Panasonic HDTV DLP (PT-50DL54) and just replaced the lamp when the tv monitor went black but still had sound. I knew I needed to replace the lamp a while ago but since the current lamp was still working, I thought I'd replace it when I had to which I thought would be now. I didn't notice any blinking lamp light. After replacing the lamp, the tv still showed a black screen although still had audio. I tried that lamp reset thing & the lamp light blinked about 3 times but still no video. Could it be more than just replacing the lamp?
Did you replace the lamp because the picture went out (black)?
hello i'm having the same problem with my tv panasonic. similar. i went black but with sound. changed the lamp and it stayed the same. i reset it just like it says to do but nothing. i left if fot a while and tried again now it's stays a few minutes on and then it's turns off. what can be the problem and what do i have to look for to change.
thank you in advance .sincerly
SOURCE: Vertical lines on Panasonic DLP
panasonic hdtv 1080i has a rainbow in the middle and shows shadow
SOURCE: how to reset a panasonic dlp lamp hours?
Try the following:
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
You can also click here to get more instructions if the above do not work. See post # 4.
SOURCE: i cant get a picture on my hdtv. i just replaced
Do you hear the fan blowing? If not, you have another problem.
Also, check all the cables.
Yes, I did. It was almost a year since I knew I'd have to replace the lamp soon so I ordered another one to have ready when I needed to. While watching a show 2 nights ago, it suddenly went black. I assumed it had to be the lamp.
