Cant accses front panel buttons. cant find remote control
SOURCE: same problem
unlock is in the tv menu not remote if you still have owners book that came with tv it will tell you how
SOURCE: I have a RCA tv that has no remote and the front
I have rca tv with no remote and the fpa is locked...how do I unlock it?
SOURCE: How to unlock the front
Best thing is go to Walmart and buy an RCA universal, cost you around $ 10
SOURCE: front panel lock
Most RCA sets use a
four digit code to control the v-chip. The code reset is different depending on
the model. Try each number until you find the one that works for you. 1.
Hold down the
MENU button on the remote and VOLUME DOWN button on the TV it's self at the
same time for at least 4 seconds. The set won't say so, but the lock will be
unlocked 2.
Hold down the 0
(zero) button on the remote and the VOLUME DOWN button on the TV itself at the
unlocked 3.
Hold down the
MENU button on the front of the TV and the TV button on the remote at the same
time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU
button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button
on the front of the TV set and the MENU button on the remote at the same time
for at least 4 seconds. Depending on the model, one of the methods should
unlock the V-chip. Now, if desired, you can change the settings on the V-chip
by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to
MENU and then going to TV SETUP, then to V-CHIP SET.
