My battery died and i jumped my car when i tried to use the key fob nothing happens. my car wasn't started for six months. i got a new battery and still the same problem with the fob. i think that my computer lost the code, is there a sequence that i can do for the computer to recognize the fob again.
SOURCE: 1994 Dodge Viper will not start after storage and battery drain.
With the battery charger connected or a jumper battery simply click the alarm key fob on and then off. This will reset the alarm and the car should start...had mine towed to find this out
SOURCE: My 1988 dodge ramcharger has
the rebuilt alternator has a diode gone and its draining the battery ,fit a new one or take it back,last question this my back is hurting from sitting at computer ,best of british with it anyway
SOURCE: I see on here where
If you have a new battery and it keeps going dead, then either you have a bad battery or the alternator is not charging properly. Altenator not charging could be either a bad alternator, loose belt, or bad wiring coming from alternator.
Testimonial: "Thanku so much for answering ~ I am going to start by replacing battery because I believe its the original battery and see if that fixes it. "
