Delta bathroom faucet with crossbar. How do you remove the unit
Do we want to remove the faucet from the top of the sink?
First shut-off the water via the two valves under the sink. Then un-thread the hoses from the bottom of the sink. Sometimes it is possible to do with ordinary house tools but more than likely you will need to purchase a basin wrench for about $10. This wrench will allow you easy access to the bottom of the faucet.
Then, using the same wrench, un-thread the nut that is threaded on the same threads as the hose. This nut if probably pretty tight and will take some effort.
Replacing is the exact opposite except when replacing be sure to use plumbers putty on the bottom of the faucet as a means to keep water from running under the faucet base and ruining your cabinet.
