Ocassionally when my wife makes coffee in our bunn it overflows over top of filter basket. it never does it with me. I checked when it happened yesterday, she only had one filter in and seemed to be pushed all the way back. Any ideas??? Jim
Do you grind your beans at home before brewing or is it ground from the store. If you grind just before brewing check her grind and compare it with yours.
Also check to see if she levels the coffee in the basket. Usually when a pot overflows it is because of the grind or the way the coffee sits in the basket.
bunn coffee pot-coffee ground overflow!!!-a couple solutions
1. drill a bigger hole in the bottom of the basket.
2. don't use bunn coffee filters. they are a higher fiber filter causing water to flow through very slow while the coffee pot is flowing out water fast.
3. Pour in one cup of coffee and set that same cup under the basket. Use it like an expresso machine. Then do the same with another clean cup or whenever your ready. It only puts the same amount out that you put in. Dont use over 5-6 tablespoons.
Why do the Coffee grounds always overflow the coffee filter?
Overflow from the filter basket onto my countertop
