SOURCE: My Keurig B60 does not run at all. The screen
Not sure if this will help, but I had the same problem over Xmas. This was posted 8 Jan, and I cut/pasted it here. Sounds complicated, but it's not. Just print it off instead of trying to remember it! I'd be interested to see if you had the same 'codes' as I, and if your machine had hot water when it ran... I have not done anything since that post...
Patient: Keurig B60
Symptom: "Not ready" light is on. Reservoir is filled and needles are clean, so problem is not user related.
Internet search yeilded some hope for another Keurig machine. While turned off, simultaneously press and release the small and med button, then menu three times. You get into a programming/diagostics menu. As you scroll (via the menu button) mine says Ready 602, Brew 265, Autooff 099, Set 007, Set/set 099, Descale 099, and Menu 000.
While at 000, press the med button but do not release. Press and release menu and immediately press small, then let go of small and med together. Pump runs and water is circulating, but is cold. Not sure if it should be cold (just a test routine, etc) or whether the heater is blown or something more troublesome.
Anyone have any ideas/experience with this information (I have no problem in ripping the machine apart if I have to. It can't be that complicated!).
SOURCE: blinking lights
let it blink for about 15 minutes, then adjust each one of the settings, then turn it off and back on, for some reason it stops flashing and will work. Warning, after doing this for about a week, mine now has no power at all. It is plugged in and the outlet works and there is no power going to the machine, it is not even a year old!
SOURCE: Keurig B40 model is not
make sure you are not using a clear mug. i did and the sensor wouldn't pick up there was a mug there. so annoying!
Here is a tip that I wrote about how to register your Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
Keurig Registration, User Manuals, Cleaning, and Troubleshooting
heatman101
