Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Computer Wont recognise the USB hard drive but IT'S THERE
Hard dive Indicator light is on Devices and printers shows it but message says it not recognised
6ya staff
SOURCE:
Madrias
  • 11 Answers
SOURCE: usb devise not recognised
You probably damaged the drive from sudden disconnection of the signal line. I would suggest trying it on one other computer before considering it trashed.
Posted on Jun 08, 2009
Anonymous
  • 13 Answers
SOURCE: 1tb Verbatim External Hard Troubleshoot
does it work on another pc ok? Do other usb devices work ok? Give me the details and I can help you solve this.
Paul
Posted on Aug 08, 2009
Puchu Sona
Bappaditya Basu
  • 158 Answers
SOURCE: my computer wont read my
USB device is not recognized http://support.microsoft.com/kb/871233
If this answer helpful please vote me. Good luck.
Thanks for using FixYa
Posted on Jan 13, 2011
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: My computer stopped while I
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 02, 2011
Dave Dabney
  • 8 Answers
SOURCE: hard drive no longer recognised
for more Do not format your hard drive. We will evaluate your drive, and if the problem is only a logical recovery issue, we will recover your data for $150 per 250GB disk capacity. You would need to provide media for us to recover to, and we would send the recovered data back to you. If the problem requires physical recovery, we could get you a quote for the deeper level recovery service. Come see us at http://htcilabs.com/services/data-recovery-services/ for more information.
Posted on Aug 21, 2012
Computer wont recognise external hdd
Follow these steps:
1. right click on My Computer
2.Click on manage
3.Click Disc Management
There you can see External hd (you can chose to activate or change drive letters and that will do the job)
Mar 29, 2013 | Buffalo Technology DriveStation HD-HC500U2...
The computer does not recognise the hard disk whenever coonected. however other devices are recognised.
Sometimes it is under my computer. check there first. If it does not show up there. some times a simple computer restart should do the trick.
Hope this helps.
May 03, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My pc does not recognise external hard drive, can see it in devices and printers section but not in my computer? any ides?
Hi kileyjones1
Go to the Control Panel and select " folders options \ view "
Check " show hidden files , folders and drives "
Uncheck " hide empty drives in the computer folder "
Your drive will now appear in the Computer Folder .
Best regards ,
fanaudi .
Apr 29, 2011 | Western Digital Elements 1TB USB 2.0 Hard...
WD Pasport USB Storage. Light goes on whirring sound but does not show connection to laptop with windows 7
Once connected to the computer via cables or wireless signals, the passport storage device is recogniseable from the list of devices added. Search from the computers storage devices area to ascertian that devices as successfully added. Also attempt to store data on the device to ascertain functionality.
Feb 06, 2011 | Western Digital Passport WDXML800UE...
ST300003U2 hard drive powers up ok, power light on, message on pc "usb device not recognised " .one of the usb devices has malfunctioned and windows does not recognise it.
Try to plug it in to another PC to see if you get the same message. See if you can run a scan disk on it from Windows to see if it's bad or going bad too.
To be honest, device not recognised is a bad sign. :(
Dec 22, 2010 | Seagate (ST3320820U2-RK) 320 GB USB 2.0...
PC not recognising Iomega Prestige 320gb usb portable hard drive. I've connected it all up, disconnected, reconnected, rebooted the computer, but the drive is just not recognised and does not show up in...
Does the drive show in Device Manager? Right click on 'My Computer' and select properties, the open device manager.. Navigate down to Disk Drives or Hard Drives, click on the plus sign and see if your drive is listed. If it is, then right click on the drive name and open properties for the drive. Click on the 'Volumes' tab and hit the 'Populate Button'. It may be the disk just needs initialising, then reformatting before you can use it. If it does need initializing, a wizard should appear to guide you through the process!
If this doesn't solve your problem, try using a different USB cable and/or USB ports on your computer, and ensure to unplug all other USB devices other than keyboard & mouse.
Mar 06, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
WD320 GB 2.0 USB external hard drive is not working.
bad driver chip... call the manufacturer.. have the HDD changed...
Jul 09, 2009 | Western Digital Passport 320GB External...
Iomega USB 2 Desktop Hard drive not recognised by xp sp2
did you set any jumppers to slave? Is it pluged in the right spot?
Nov 24, 2007 | Iomega HDD External Desktop (32660) 80 GB...
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
27 people viewed this question
Top Verbatim Computers & Internet Experts
ChinthakaJ
ChinthakaJ
gggg
Duncan Mutch
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
