Ford service light procedure 1994-01
Windstar
1999-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the message center, press the SETUP control to access the System Check mode. Press and release the RESET button until IF NEW OIL HOLD RESET is displayed. Press and hold RESET button until OIL LIFE SET TO 100% is displayed.
Windstar
1997-98
To reset "CHANGE OIL SOON/OIL CHANGE REQUIRED" message on the Message Center, press "RESET" and "SETUP" controls at the same time. "OIL LIFE % HOLD RESET NEW" will be displayed. Press the "SETUP" control to access the System Check mode. Press "RESET" to start the system check. Press and hold the "RESET" control. Press "RESET" and "SETUP" to reset the system to 100%
Explorer,
Mercury
Mountaineer
1997-01
To reset the oil life feature on the Message Center, press and hold the "OIL CHANGE RESET" button until the system counts down (about 5 seconds). The Message Center will display "OIL LIFE RESET TO 100%"
Probe
with Analog Dash
1989-92
When "SERVICE" is illuminated on the Vehicle Maintenance Monitor on the overhead console, press the "SERVICE INTERVAL RESET" button located directly above the light.
Probe
with Digital Dash
1989-92
Probe
with Digital Dash
1989-92
When "SERVICE INTERVAL CHECK" is displayed is displayed on the far left side of the instrument panel, press the "SERV OFF" button, located on the speed alarm keyboard, until three tones sound.
Thunderbird,
Mercury Cougar
with System Scanner
1986-88
When "SERVICE" appears on the Diagnostic System Scanner, press the "ODO SEL" and "TRIP RESET" buttons simultaneously. The "SERVICE" message will go out and three short beeps will be heard when the system is reset.
Thunderbird,
Mercury Cougar
1989-94
If "CHANGE OIL SOON" or "NOW" is indicated on the Monitor, turn the ignition on, but do not start the engine. Within 16 seconds, insert a paper clip into the cavity to the left of the display and depress. The display will flash; when it stops, the system is reset.
