BMW overheating
many things could cause the overheating. broken water pump impeller, stuck thermostat, clogged radiator, inoperative cooling fan on the radiator.
i would first check to see if the cooling fan on the radiator is working. when it reaches operating temp (or surpasses it in your case), see if the fan attached to the radiator kicks on. if its not on, then either the fan has failed or the temp relay to kick on the fan has failed. also, make sure the connector is plugged in.
after its at operating temp, turn off the car and feel the radiator. if you feel cool spots, then it is clogged and needs replacing.
wile under the hood and car is off, feel the upper & lower radiator hoses. if one is hot and the other is cool, then either the water pump (actually the impeller on it) has failed and is not circulating coolant through the radiator. a common problem in this model.
but it could also be the thermostat. if failed, it would not allow coolant to flow & circulate.
hopefull one of the above items is the problem. good luck.
have u try bleed the radiator ?
