SOURCE: WIll not work with Comcast, DirecTV, DishNetwork Remotes
Hello! I just got my Directv remote to work with my GE tv. I started by trying code 11922, and when that didn't work, I followed the Directv instructions to find a set-up code manually. After I followed the instructions below and doing it about 6-8 times, it started working! (So I guess the code 11928 - 11930 might work?) Good luck! I'm still having problems getting the "video" setting to work to switch inputs, but I'll keep trying...
SOURCE: my ge tv digital ready?
Your TV is NOT digital ready. IF you do not have cable or satellite, you will need a converter box. If you do have cable or satellite you have nothing to do or worry about as the cable or satellite box will automatically do the conversion for you. Hope this helps
SOURCE: TV locked on channel 3 and have no remote
Thats EXACTLY what happened to our tv!
Ours was originally locked on channel 4 but I left it unplugged overnight and now its oddly stuck on channel 3.
The only thing I can think of to do is try to search for/buy a remote that will work on the tv to bring the menu up again. I don't know how to manually reset it or do anything.
SOURCE: I have GE XS Stereo Commercial Skip Model 27GT619
This information is from the User Guide that came with our set. Good Luck.
2. Skip this step
3. 0 Exit
SOURCE: My GE tvwon't turn on with tv button or remote-just clicks
Most likely there is a problem in the power supply circuit inside the set. This probably would not be cost effective to repair. Thanks
