I accidentally took photos without an SD card in that I'd like on my computer. I've been able to transfer the photos from the internal memory to an SD card before by using the "copy" option, however when I try to choose "copy", it won't let me. The option is grey instead of the black ones that you may choose. Anyone know how to get that option to work or know any other way to transfer photos from the internal memory to an SD card?
SOURCE: Photos stuck on integral memory?
When viewing pictures, select the 'Menu' option. Scroll down and on the second page there's a 'copy' function that can either transfer photos from internal memory to a memory card or vice versa.
I didn't know this was possible until today, either. Handy!
SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
SOURCE: copy images from pc to Lumix TZ5 SD memory card?
yes i m sure it would work if you use a card reader instead of using the camera directly connected.. in that case your memory card will just work as the usb hard drive and you can load anything into it..
SOURCE: How can I transfer photos from internal memory to
should have option for that in the menu,,,
SOURCE: How can I transfer internal memory pictures to an
In the menu system of the camera, scroll until you find "copy" where you are given the option of copying the internal memory to a card in the camera.
Note: When the camera is connected to a computer using the USB cable with a
memory\picture card in the memory\picture card slot, the computer will
only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
Note:
